SSD Plus III Extreamly low write speed
Hi guys, i’m having some trobbles.
When im playing game, i can see that my ssd spikes to 100% usage sometimes and the sttutering join. i was looking for some info and i decided to compare the speeds.
Those are mine
read speed its fine but write speed its half that its notmal i think. Even my other HDD has more writing speed:
i need some help please.
Thanks!
Hi @Roberqc,
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for the best assistance and troubleshooting:
https://kb.sandisk.com/app/ask
However, problems like SSD drive running slow may arise during the usage. An important reason why your SSD drive becomes slow is the improper boot sequence – if the hard drive (not SSD) is set as the first boot device, you’ll experiences an obvious decrease in the fetching and loading speed...
Wrong boot sequence simply would not boot at all.
Its more likely they have a super full low end ssd combined with it being the boot drive leading to it being overloaded as os’s love doing lots of small reads and writes, perhaps if they have low ram its slamming the swap file as well.
#SanDiskUserRewards
Any update? I am waiting for your reply. If you are looking for a paper writing services review but can’t find any good website for it doesn’t worry you can go to this website https://www.topwritersreview.com/reviews/essayusa/ here you can see many essay examples which help you to complete your essay writing task.
