Hello!
I bought my sansa e250 some time ago and it worked just fine and my computer detected it. I have not used my sansa for some time and now that I want to use it again, I plug it on my computer, the battery which is running low is charging but the sansa is not deteted by the computer. In fact the sansa’s windows does not display the screen it used to when it was charging. I have tried almost everything I have read in the support guide but nothing works. The only thing different with my computer is that over a year ago, to fix a problem, I had to get windows xp reinstalled.
I have tried connecting the sansa to different usb ports. Tomorrow I´ll try to connect it to a usb port in the back of my computer, but my usb port hub is working fine, I have some other devices connected there.
I really appreciate your comments and help.
Thanks in advance
