i got a sansa e250. when i got it i turned it on and it kept saying battery too low system shutdown. i tried connecting it to the computer but it doesnt show up in my computer or in windows media player. i thought it might have been that i don’t have the right version of windows media but i do i have version 11. i kept trying and trying but nothing works. i even tried to add the hardware manually but it still didnt work. can someone please help me!!!
guessing it needs a new battery. Dont blame it on me if you spent money on a battery and it didn’t work. I’m not 100% sure.
There are some things you can try, like different USB ports (no hubs) and maybe a different computer or AC charger, but if these things don’t help put a charge into it, I would return it if you just got it.
You paid for a working unit without problems. That’s the very least you should expect and accept. ![]()
If the battery is critically low, try this:
Hold the power / menu button down for 15 seconds to reset the device. Leave it turned off.
Let’s try giving the Sansa a bit if juice, WITHOUT the confusion of data transmission. If the Sansa is having comm troubles, it will “forget” to charge.
Thus, our solution: connect the 30-pin data cable to the e200. Now for the careful part. The USB standard includes a clever design for the data connection- the power pins are designed to mate before the data pins to help prevent communications problems. So, slowly insert the plug about half-way, while observing the Sansa’s display. As soon as it powers up, stop. Keep the data pins (center two) from connecting.
In this way, you can manually charge a critically low Sansa battery, allowing you to troubleshoot the communications issue next, after the machine has charged up.
Let us know if the Sansa powers up when plugged in.
Bob :smileyvery-happy:
Try connecting it directky into a the wall circuit. The USB adapter can fit into certain phone wall chargers. Try that. That’s what I did when mine was not charging on my computer. It worked! IDK if it will work for you. All the best ![]()
