possible screen replacement??
my sansa fuze 8gb screen was scuffed pretty badly and i cant find away to remove it. is there a way to remove the screen and replace it without any harm the the player? if so where can i buy a replacement screen?? i need help!!
Sorry. :cry:
No & nowhere.
The only thing you can do at this point is attempt to buff out the scratches. There are many discussions on the subject here. Do a search and see some of the suggested products and/or techniques.
well thanks. ive done some researching and i think im just going to buy a good rated product and use it.
Depending on the severity of the scratches suffered, you may have nothng to lose either way. Either it works or it doesn’t. There are some excellent tips & suggestions for this procedure here though. I really suggest looking through them before you tear into it.
Good Luck!
Message Edited by Tapeworm on 02-03-2009 06:36 PM
Search the archives here for “screen scratch”.
There have been several long threads with actual techniques and appropriate products, with links, to remove the scratches.
