I’m noticing my 8TB HDD is much slower than usual, and I’m wondering if drive health could be the issue. Could bad sectors or wear affect performance, and how can I check for this? Any suggestions or tools for diagnosing the problem would be greatly appreciated! ![]()
If your 8TB HDD is slow, bad sectors or wear might be the cause. Use CrystalDiskInfo to check the drive’s health. Run CHKDSK (chkdsk X: /f /r) to find and fix bad sectors. You can also check for errors in Disk Management. If the drive has issues, back up your data and think about replacing it.
