Hard disk is slow
My 1 tb wd hard disk is slow in responding. It is also slow in transfering data. What should I do?
Did you check the health of your drive?? Here, I suggest you to keep a regular check on your drive’s health because if your drive is having issues like bad sectors then it may occur problems and also may lead to a data loss situation. Keeping a check on hard disk drive issues is not that challenging if you’re using a proper tool. Mechanical hard drives are quite sensitive and prone to physical failure or crash. Mechanical shock, corrupt drivers, improper use, or mishandling of drive or system can cause disk errors that can lead to logical corruption, mechanical failure, and physical crash.
Here I suggest you to check out the below blog which will take you through the most effective methods to keep a thorough check on the hard disk health and also help you to stay more productive by scheduling the disk checking and optimization tasks: https://www.stellarinfo.com/blog/how-to-check-hard-disk-health/
Hope this will help you out.
