I have a Presley,Elvis folder and a Presley,Elvis-Live folder as separate folders in MyMusic. When I copy to my Clip +, they get merged into one file. How can I keep them as separate? (I have the same problem with other artists where I also have a “live” folder.)
Forgot to say I am in MSC mode. And, I use the copy folders method to load Clip +.
I’ll post the answer to my question, so someone else might find it if they search. The Sansa does not read the entire folder name. It lumped Presley,Elvis-Live with Presley,Elvis-No.1 because it only read “Presley,Elvis” and put everything into the Presley,Elvis-Live folder (because Live precedes No.1 alphabetically). No, the Presley,Elvis-No.1 folder name did exist at all in the tree.
The solution was to create a Presley,Elvis folder, then two subfolders; a Live and a No.1 subfolder. Then, all songs were where I expected them.
7o9, all songs are properly tagged. So, apparently, the tagging has nothing to do with reading folder names.
