I’m using a SandiskSSD Plus 240gb over a year. It has really high total nand writes and it’s increasing even tho host write is low. First months it was going almost same and didn’t check it untill today. Now it looks so bad. It will be dead in a 6months if goes like that isn’t it ?
I checked with the SanDisk support team and your incident has not been closed. your incident was escalated so a a support engineer can look over your support request. Someone from the SanDisk support team should be in further contact with you soon.
