Battery Q: Is it okay to leave Fuze plugged in a lot?
Hi All,
I plan to use my Fuze to entertain me during my commute. I have a FM transmitter and a car charger for it and I can have them plugged in at the same time, so I won’t have to worry about the battery dying while I’m driving. Would it be bad for the battery to leave the Fuze plugged into a charger most of the time?
Message Edited by canaws on 12-26-2008 11:18 PM
The Fuze’s charging circuitry will shut off when it’s ‘full’ and besides the power will be shut off to it when the car is turned off, won’t it? Besides, you’re going to want to un-plug everything and take it with you or at least hide them out of sight to prevent break-in’s aren’t you? :wink:
Everthing does come unplugged when I turn off the car. Since it stops charging when it’s full then I guess it’ll be fine. Thanks.
