After Firmwareupgrade Problems to Charge
Hallo everybody,
first i have to say sorry for my bad english and so it would be nice if you keep your words simple for me.
Ok back to topic.
I have Fuze 8GB Revision 1 and the Firmware 1.1.11 was on it. Two days ago i thought about to search new firmware
to get some new features maybe.
So i found this Forum und made an update with the SanDisk Updater to Firmware 1.11.22
After this Update everthing works fine, bur 1 big Problem!
When i plug in the usb connector to the pc it charges the fuze about 1-2 minutes and then it stops charging and
the battery of the fuze ist only loaded 10%.
If i put the fuze on an extra powerconnector with an USB Port to charge it stops charging after 1 minute and the
battery is still only 10% full.
No I changed the Firmware back to 1.11.15 an the fuze charges when i plugthe usb connector
to the pc but same problem with the extra charger without pc.
The difference and the reason i see in the specification of the extra charger.
The charger is specified with a current of 400mA. A normal USB port at the pc
is specified up to 500mA.
Could this be a reason for one of my problems?
I have just orderd a new charger with a specification up to 750mA and so i´ll see if this is the reason.
But one Problem isn´t solved by this way, wehen i put the newest firnware 1.11.22 on it
it isn´t possible to charge the battery of the fuze at a usb port at the pc.
So has anybody or had anybody the same problems and could give me an solution for this.
Ralf
