Recently, the drive itself is locked, there is a padlock. The disk was formatted and it worked for one day. Some data has already managed to put back there, and he himself blocked again. I do not have set any password! Drive has locked itself once again! This is a joke … What now? Should I format it again? And once again lose my data? Help!
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
The problem is solved - or not???
The problem is still unresolved. I eresed drive once again and this time I established my own password. But again after a few uses of the drive has locked itself. My previously set password does not work.
up
Why I bought it … I should buy something cheaper because, as you can see… more expensive more problems. And as we see in this forum the problems with passwords often appear.
