Hi
Checking ‘version.sdk’ I get ‘Region: Americas’ on my Clip+. Normally I wouldn’t mind, but I’m in Europe (UK) and am wondering if there are any implications regarding:
a) Returns if an error occurred (I bought it from Amazon.co.uk - so it’s legit)
b) Character set, my system is obviously a UK one and there seems to be a difference between the US and the UK locales (at least on Linux), I’m guessing there shouldn’t be an issue as the American set is installed to support other USB sticks.
c) Updates. Can I over flash with an EU version?
What is the difference between the regions on the player? Apologies for seeming a little blunt, but please only reply if you have experience with this ‘issue’ with the old clip, or if you have solid knowledge. Guessing isn’t of any use.
Cheers
