hi guys , have some questions regarding the 3tb My Book Essential …
kindly bear with me on these
 if you don’t mind kindly answer each after every question for easier cross referencing
- my laptop runs Windows 7 Basic 64 bit … do i need to run any kind of formatting first of the 3tb prior to usage to avoid problems arising later on while connecting the 3tb to my laptop … format using the WD software , i think it is called the WD QuickFormat program … or any other formatting software perhaps ? what are your thoughts ?
1.a. will my laptop automatically recognize the 3tb upon connecting it , without doing anything preparatory first
btw , i have read that there is an issue when it comes to the usb part of the my book essential usb 3.0 … am i correct that the problem pertains to this : the usb 3.0 part of the enclosure would fall off … as in literally fall off from the enclosure ? so it’s like pulling out the usb part of the enclosure… is that it ? … or the problem is simply the usb part of the enclosure is wiggly at times ?
does the problem have a correlation to the size of the drive … so a 2tb or a 4tb would be better instead of a 3tb … ?
3.a. does the My Passport have the usb issue also ?
- what remedy can you possibly think of to avoid the problem ?
4.a. does keeping the usb 3.0 cable always connected to the enclosure ( meaning the usb cable wouldn’t be unplugged anymore ) really avoid the problem altogether ?
- does the power connector of the enclosure have issues as well … the power connector falling off perhaps ?.. so it is better to keep the power adaptor always connected to the enclosure ?..
thanks guys for the time … hope you guys can share some info here , thanks again
