WD Unlocker doesnt work
Hello, I have WD My Passport Ultra 1 TB. ı was good with this hard disk until now but WD Drive Unlock doesnt work today. When I want to use my Wd Passport Ultra, I always use password. But when I use WD Drive Unlock, it doesnt open password page. It is working and I have to wait a lot and then it says ’ Unknown Security State: ff’. Are there anyone who saw this problem before and how can I fix this?
Hi gigas,
Please try to unlock the drive using WD Security and let us know if the issue still persist. Please refer to the link given below in order to setup WD Security.
https://support.wdc.com/knowledgebase/answer.aspx?h=p1&ID=10408&lang=en&p=120
I’m having the exact same issue.
Any solution yet?
Actually WD Support didnt help enough. They said what they must say.
Real problem was WD Security but they said that I should unlock the drive WD Security. Problem can be solve easily if you are lucky. I use macbook. I tried hard disk on different laptop(not macbook). And I can unlock the drive using WD Security. Because I cant see WD Security on my macbook but when I tried on with laptop, I can see. And then I delete password from WD Security. After that when I use hard disk on my macbook, there was no problem.
I updated WD Security on my hard drive, then I was able to get into My Passport using that.
