hi
[[[after re-installing windows my wd passport hhd not unlock even I used my password]]]
plss help…
hi
plss help…
Have you tried on another computer?
And do you check hdd condition ? Spin well?
Lastly I have to format WD 1tb completely ,and lost all data (![]()
(((((Even I have tryied another PC it occur same fault . ))))
complete erase? or you can try some data recovery software for scan data?
Yes I tryed… But not recover
i am so sorry i think i said wrong. cause it has encrypted that use such software no help. i think may be we can try to decryption it if you do nothing after format(no write data into it). i am no sure this way will work or has chance. never do such before. just has ideas
