After coming back from holiday I went to use my WD Passport as I usually do for my University work. However when I plug this in via the USB port on my brand nee Macbook Pro it is not recognised whatsoever! (Not even in disk utility)
With my limited knowledge I took to the internet to do some research, and I then tried the Passport in my iMac where it is also not recognised, however this times it was recognised in disk utility. I verified this this using the button and it says “The partition map appears to be OK”. This leaves the “repair disk” button able to be clicked.
However I am useless and don’t want to make any mistakes so I was looking for some advice, I have only owned the passport for the best part of three months and it contains some work that I have not backed up and plenty of photos that I would not like to loose. (A lesson has been learnt already).
Please could someone advise me on the best way to gain access/fix my problem.
Thanks in advance!
