Can I use a different drive for replacing the RAID 1 array, replaced the defective WD 500GB with a new Toshiba 500GB and power up? “System should automatically rebuild the RAID. The outer ring will turn in a clockwise motion during drive activity” It just light up blue, it doesn´t seem to work at all?
Take a look at this link:
At the bottom of the page it says:
| Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss. | |
Yes it works fine with a Western Drive, “problem” solved!![]()
