Hi everyone
My WD drive does not back up and after I installed an update it wont even open. There is a message that appears very briefly but it disappears so quickly I can’t even read it.
This is an older drive (approx 2 years old) but it should work and I don’t know what will happen if I uninstall the software and how to install it again. My late husband used to take care of all such things and I am a bit lost here. Can somebody help me, please?
Thanks a lot Sue
Hello, What software are you using? I guess that is the WD Smartware, if you provide me with the drive model number, I will be able to tell you where to download the latest version of the software.
Hi Iluna
Thanks a lot for your reply and offer to help.
The software is the WD Smartware and the drive is a My Book
Essential WD (that's what is printed on the front where the plugs
are). here are some labels on the side as well but I believe my
husband may have put those on as they sound a lot like the
information of his netbook (Aspire One 722).
Sue
Hi, you can download the Smartware from the link below. Uninstall the Smartware from your computer and download and re-install it again.
Thank you so much for your help. I will do this this afternoon.
