Topic name says it all… I installed WD Dashboard (latest version 4.1.2.4) today, clicked the “Info” icon for both of my WD Green drives, and noticed that the listed serial numbers looked nothing like what my own records show for them (and WD DLGDIAG.EXE confirms my records). After several minutes of scratching my head, my computer-generated dyslexia kicked in and I finally realized that the serial number strings are an exact mirror of what they should be…
These drives are both in external USB-connected trays, but that’s never stopped DLGDIAG.EXE from reading them out and testing them correctly. Also Samsung Magician has no problem reading the data from these drive. Here’s what I’m seeing in WD Dashboard for both drives (S/Ns are partially redacted):
Drive Summary
Model Name: WDC WD20EZRX-00D8PB0
Model Number: WDC WD20EZRX-00D8PB0
SATA Revision: Gen3
SATA Link Speed: 6.0 Gb/s
RPM: 5400
Serial Number: ****ZCEM4CCW-DW
(etc.)
Drive Summary
Model Name: WDC WD20EARX-00PASB0
Model Number: WDC WD20EARX-00PASB0
SATA Revision: Gen3
RPM: Unknown
Serial Number: ****575AZAMW-DW
(etc.)
This is my first time using WD Dashboard so I have no idea if this bug is present in previous versions…
A bit of feedback while I’m at it:
The overall layout of this program is bass-ackwards. Drives need to be selected individually before the drive-specific Overview and Tools sections can be viewed. So naturally the My Devices section belongs at the TOP of the left-hand navigation pane (not in the lower section of that pane).
Model Name and Model Number fields shouldn’t show exactly the same string. Maybe one field is supposed to be a subset of the other, and WD Dashboard is also having reading comprehension issues in those fields as well?
I did press the GENERATE REPORT FILE button in the program and it created a valid Dashboard_Report.zip file. That archive includes two .bin files for every drive installed on my PC. Those filenames also use the drive serial numbers. The .bin files for my Samsung internal SSDs have filenames that match my known serial numbers. However the .bin files for my Western Digital external HDDs are using backwards serial numbers (just as erroneously displayed within the program).
WD Dashbard says “send the file by email to our support team” but nowhere is that address listed in the program. Nor can I find it on WD’s support website. There is an “Email Us” page at https://support-en.wd.com/app/askweb but it doesn’t have a Product Category for “Software” or “Apps”, and the category for my WD Green drives is not in the Product Name pull-down menu, and for a final insult, that page does not allow .zip attachments(!)
One, two, three strikes you’re out WD! ![]()
