Very slow transfer speed
hello
I went through the forum but I can’t find a solution to my problem
The problem is my transfer is very slow it run between 300kb and 2 mb
  1. i formatted the drive but still the same problem
  2. I tried the WD utlity to do a scan and it keep saying failed.
  3. I changed cable and the same
  4. i try different PC and the same result
  5. i deleted partition, created new and same issue
any solution? Yes i do use it on usb 3.0
Please refer to the following KBA article: Network: Common Causes and Solutions for Slow Data Transfer Speeds
