To Sandisk: Fuze power switch complaint (minor, but worth noting)
I’m a generally happy owner of 2 fuzes and also the owner of 2 clips.  The only slight issue I have with any of my units is the insignificant/hard to operate power/hold switch on the fuze.  By comparison, the power switch on the clip is much, much better and easier to operate.   I realize that changing the fuze’s switch would involve a design change and a somewhat lengthy lead time; but if it is to continue to be in the product line, I would look into the possibility of changing it.  If the fuze’s days are numbered, you may want to look long and hard at it’s replacement’s power switch before it goes into production.
Heck, I may be in the minority here, but I thought I would address the issue.
PS. Since this is an opinion on an existing feature set of the player, I placed this post here instead of the new features area of the forum.
First, I hope the Fuze’s days are not numbered(although I have ideas for a replacement, but that’s another story)…that said, I am in agreement with you on the power switches of the 2 players. I’ve never had a skin on my Clips, is it still easier to use with one than the Fuze? I know I took an X-acto knife to my silicone skin for my Fuze, to make the power switch easier to access. The switch and surrounding area are the only spots where there is slight paint chipping occuring, so the alternate switch like you suggest would eliminate this too.
Yeah, good point Marvin.  I’m basing my opinion with the player as it is without any add-ons.  Clearly the switches will be a bit more difficult to navigate with protective cases.  Even without a skin, the fuze’s switch is more difficult to operate than the clip’s.
I have to agree.  Never had a problem with the clip’s power switch but do sometimes have trouble with the fuze.  The little ridge on the slider is a bit too little I think.  Still love the device though.
I agree.  The on/off switch needs to be replaced.  My coworker has an old E2?? and the button to turn on/off is so much easier.
I have a silicon cover on mine (helps protect it and I use the belt clip that came with it everyday) and it’s hard to use.  I can use my finger but on some days I use something else to turn it on or off (depending how I’m feeling :smiley: or if I just don’t feel like bothering).
I would love to see a properly integrated push button switch on the fuze maybe on the side somehow. I love the button on the Connect. So something like that on the fuze would be cool, as long as its simple on/off not like the Connect with sleep mode…
I don’t have any Clips (I love the expansion card slot too much), but I’m in 100% aggreement about the Fuze’s on/off slider switch.
I’ve posted numerous times here on this ‘design shortcoming’, especially when comparing the Fuze to it’s predecessor, the e200 series. On those, the power/on-off button is incorporated with the ‘Home’ button of the face of the unit. A short press takes you ‘home’ or to the main menu and/or back to the ‘Now Playing’ screen, whereas a longer press turns the unit off.
There was no problem with this arrangement; I don’t know why they changed it in the 1st place. If it ain’t broke, don’t fix it! :wink:
I wouldn’t have gone with the current arrangement, especially in light of having worked with the ingenious e200 series power / menu combination button.  This arrangement is the one characteristic of the previous Sansas that should have been kept.
It works, and it works very well.
The flat baton of the Fuze power switch is, well, designed to encourage me to take a deep breath, and have a therapeutic long sigh of resignation every time I power up the device.  Ah, if it had only been done this way…
That wee flush mounted baton is designed for arthropods, not humans.  Try the power / lock switch on the Sansa Clip.  Much better. Heck, pick up the Sansa View, and see that it’s power switch is a breath of fresh air in terms of physical tactabilities, after the aggravation of manhandling that microscopic…thing…on the side of the Fuze.
Call me silly, but if you can figure out why hiding the power switch in such a fashion won as the piece de resistance for the top of the line device, I’ll come over there with a manicurist to repair your fingernails.  I mean, the objective is to turn the happy wee beastie ON, and let everybody see how nice and happy it is to work with such a marvelous little player.  Having to borrow a bobby pin, PDA stylus, toothpick, pencil tip, paperclip, leather awl, screwdriver, icicle, used bicycle spoke, centerpunch, X-acto knife, uncooked spaghetti noodle, tinkertoy stick, chopstick, the tip of your eyeglass temple, knitting needle, oscilloscope probe, test lead, thermocouple tip, pipette, syringe, soldering iron, poker chip, edge of a Dorito, or whatever, in hopes of prompting your happy Fuze to life, there’s something wrong, folks.
The current Fuze is limited, if I understand correctly, as the start interrupts are limited to one dedicated line, meaning that the e200v2 has its start line hardwired to the menu button, and the Fuze has the line configred to, well, that funny thing on the side. I am not talking “apples and oranges” here, as the AS3525 processor controls both machines.  I don’t think redirecting the start key to the Home button is possible via a firmware change, if we’d like the Fuze to have acceptable battery life while in standby.
The solution?  What works for me is a good sense of humor, honed from years of riding the tailboard.  Oh, and at least one improperly trimmed fingernail helps.
In the future, a proper switch baton or slider would be most thoughtful.  I have made some from ABS plastic that rest atop the current one, giving a 0.7mm raised surface that is operated with ease.
Bob  :stuck_out_tongue:
Nice rant.:smileyvery-happy:
A nice crusty callous on the side of your thumb helps too !
Actually, thank G-D, I don’t have to even use my fingernail to slide up the power switch, I just push it up with my finger.
I think the point of having that microscopic switch it have it look nice. I used to have a Clip (loved it…before it was stolen), and the switch was HUGE!!! I liked that. I bought a nice little clear plastic cover for my Fuze, and it is now virtually impossible to turn the thing on/off. If anything, they should make the little bump in the middle of the switch a little bit bigger.
Message Edited by saxmaster765 on 06-01-2009 09:23 AM
