I have a Sansa Clip 2GB Black that is not recognized by the system. I have tried uninstalling and re-installing, loading USB storage drivers and get a type 10 error. I know that for the clip to be updated that I have to be in MSC mode. There is no way to change modes on this Clip, that option is not available in system settings. There must be some hardware way of changing it to MSC mode manually, so it can be updated. Otherwise this just a useless piece of plastic and chips. I know that the system sees the clip, it just refuses to recognize it. By the way, I have Media version 11 on the computer.
If anyone can help that would be great, otherwise it goes to the recylcling center and I’ll never buy another Sansa MP3 product.
Well all, I figured it out and it works great now, but only in MSC mode. Windows media player 11 will only recofnize it in MSC mode. But it works so great!
after spending more thand 10 hrs looking for a solution for my 2gb unrecognized sansa clip on sp2 and sp3 BUT it was recognized by vista ,and after reading tons of internet solutions and forums ,the only solution (which worked for me) plug the sansa to pc with vista os and make sure you have the latest firmware if not please upgrade to the latest ,then choose setttings/usb mode/msc…its finally recognized by windows sp2 but not as a mp3 BUT as storage device
however,i missed 2 features at this solution 1-the sansaclip would no longer charges from the computer (usb charging)instead u could get a charging adapter from amazon which i did long ago.
2-i miss the sansa icon at the right corner which i really likes
instead of all that install windows vista which is a genie device recognizer
Thanks so much guys, the net command resolved the problem I was trying to fix (forced MSC mode and would get “USB Device Not Recognized” message upon connecting).
How exactly does that particular command address the problem? It looks like it added a new(?) user to the administrators group - why was this necessary?
