Greetings,
Sometimes, while listening to certain audiobook tracks, my Clip suddenly skips to the next track. If I back up to the track I was listening to and fast forward to where it skipped, I find that it skips to the next track in the *same place* every time. For example, I’ll be listening to Track 3, and at 25 minutes and 2 seconds, it will suddenly skip to Track 4. If I start Track 3 again and listen up until 25 minutes and 2 seconds, it will skip to Track 4 again, every time. Some other facts:
-I’ve experienced this problem on 3 different Clips (1GB and 2GB models), all refurbished, but all with the latest firmware loaded (v.35A)
-All audiobooks are downloaded and transferred with Overdrive Media Console, from two different laptops, both running Windows 7
-All tracks are .wma format
-Most tracks work just fine
-Tracks that don’t work appear to be affected at random; i.e., there’s no way to predict which track will have a problem
-The time at which the track skips appears to be random, but it will be the same time for any given track
-Deleting the file from the Clip and re-transferring it seems to fix the problem for that track
-If I delete an entire book and re-transfer it, I’m likely to get a different combination of tracks with problems; i.e., tracks that didn’t work might start working, and tracks that used to work might start to skip
-I’ve tried reformatting the memory after upgrading the firmware… same issue
-I’ve tried uploading it to the Audiobook folder vs. the Music folder… same issue
If it had happened on only one device I’d chalk it up to a manufacturing issue, but three separate players?? I’m a software developer and diagnose bugs for a living, but this thing is utterly beyond my comprehension and driving me crazy!
Ideas??
-Michael
