I’ve just bought a 2gb Sansa Clip, but I’ve noticed that the song (both browsing them by clicking “Play all” or “songs”) aren’t actually in alphabetical order, they are sorted by initial letter but then there are some “errors”.
For example:
-Around the world
-Atwa
-A Modern midnight conversation
-All right reversed
I’m connecting it to my PC ad “Msc” and I’ve copied the mp3 files directly in the “Music” folder, without any other subfolder.
One thing I’ve noticed is that songs which have been copied to the Clip in MSC mode do not always show up in correct alphabetical position compared to songs copied in MTP mode.
For example, I have a song called “Cymballine” (Pink Floyd for all you oldsters out there) that shows up before “Cat Scratch Fever” (yep, I’m an oldster). The first was copied in MTP mode, the second in MSC mode.
When you install it, you have an option to add to context menus–allow that.
Open and go to Tools/Options/Tags/Mpeg. Make the tag version ID3v2.3 ISO-8859-1. Those are preferred by Sansa. You can save that as a default.
Open one of your albums and highlight all the files. Under Convert you can choose Convert Tag to Filename. Put %title% in the window and the files will be named as the titles. Then, under Music on the Clip, scroll all the way down to Folders and choose the album and it should play the songs in order by filename, which is now in alphabetical order.
This preserves the track numbers, in case you’d prefer to hear the album as the musician intended.
