Can I load music on my sd card first from my computer and then put it in my fuze,or does the card have to be in the fuze to load the music.thx.
I always load my music into the memory card from a card reader; not the fuze itself. I have one of these and it’s just more convenient to load the music onto it rather than the unit directly.
Sure. You can organize the SD card with folders and files any way you want. If the tags are correct on the music files, the Fuze will organize them into artists and albums for you. If you want to transfer DRM protected files, however, you have to have the card in the Fuze.
The fuze does not take SD cards. It has to be a microsd.
I just fold my sd card to fit the slot…
:smileyvery-happy: :smileyvery-happy: :smileyvery-happy:
No magic wand required? ![]()
