I have had my fuze for three years and it’s only had one minimal problem before, Now the wheel is doing something wierd to my fuze. i can turn it as much as i want, and it won’t turn up or down the volume,and i can’t scroll through menu options anymore! what is happening, and what can i do to fix it?
i spilt soda on min but i put about 3 dropes of WD40 in it and now it workes [in damp places min dosn’t work(don’t tilt it down when you put the WD40 in it or youll brack the bottem butten)but it workes and it was 2 weeds and i didn’t need to put more in it but befor you do this there’s another forum about this and it has a safer fix but it didn’t work on min.:smileyvery-happy:
Wow! Someone needs to utilize the Spell Check button.
what other forum is it?
Volume disk not working
"12-21-201007:08 PM “I have had my fuze for three years and it’s only had one minimal problem before, Now the wheel is doing something wierd to my fuze. i can turn it as much as i want, and it won’t turn up or down the volume,and i can’t scroll through menu options anymore! what is happening, and what can i do to fix it?”
If the wheel turns but doesn’t produce the proper effect, then it might be that the firmware in the player is corrupted. Download the latest firmware, and manually install it on the player. If this doesn’t work, then it is likely that you have a hardware problem, and you should buy a new player.
