Hey guys,
This is my first post here and I am looking for an answer.
I have the Fuze 4GB Black.
It works great and I really love this thing!!!
My problem is probably my own fault but I can’t seem to correct it.
I got it before christmas and I filled it up with as many songs that I could - It was full with only Kilobytes left.
For christmas I requested an 8 GB memory card also by Sandisk, and started adding songs and albums
to it.
I can listen to everything using headphones, I can get internal and external memory to no end.
I have a radio that has a usb port right on the front and I could go through the entire Sansa files using the UBS cable and play everything.
There was a bunch of numbers that would show up before each song title when I used the radio, so in my infinate wisdom, I decided to “clean up” those numbers and I removed them from my files in the memory card.
I did this through my computer.
Now when I try to listen to the sansa through my radio all I can get is what is in the Internal memory and somehow I do not have access to the external card.
I reformatted the sansa - added songs to the internal memory and still the same.
I reformatted the Memory stick added songs - same issue
I reformatted everything Sansa and memory card and add songs to the card and I can get the card but when I add a song to the internal memory, I lose access to the card.
Also I reflashed the Sansa with the updated 1.02.31 version Same issues as above.
My thoughts on this are: (Man you really F’ed up here), Well that is my initial thought :)
Is it possible that if there is open space in the internal memory, that it takes priority over the memory card?
Will I have to buy another memory card?
Is it possible to reformat the memory card and wipe it clean?
I can still listen using the cord and input option but I lose control of file selection through my radio.
What did I do and what can I do to fix this?
