My sansa player e260 screen wasnt working but the unit is operating and everything, I found out that the lights is not working… Can any one help me?? By the way im in Egypt There is no support center here i think.
Here are some Images:
Screen with flash:
http://img338.imageshack.us/i/06102010583.jpg/
Screen Cable or whatever it is:
http://img704.imageshack.us/i/06102010580.jpg/ (FRONT)
http://img836.imageshack.us/i/06102010579.jpg/ (BACK)
I founds this fix on another thread and it worked for me.
Take the back cover off by unscrewing the 4 little screws. If its like mine, there will be a black rectangle running horizontally across the top. When a smaller rectangle inside that one running vertically to the right of the middle. Gently press on the smaller rectangle until you feel/hear a little pop (like pressing a button). I took the battery out and waited about 5 minutes before putting it back in and turning it on. Didn’t think it was gonna work and I’m not sure why it did, but it has saved my media player!!!
