Uggh. I use my clip for my long runs and this is annoying!
Suddenly I can’t get my play lists from Rhapsody to go to load completely onto my clips (I have two, a 1GB and 2GB). My other 2GB seems to be working fine.
It transferred about 20 songs then just got stuck transferring. I got no error messages. I have tried the simple fixes (MTP mode, de and re authorize) but to no avail. It worked fine until I deleted all the songs (off of the 2GB only) and tried to reload the play lists.
Help! I need to run!
I think you need to format the device and try to update the firmware and we can also try to check the subscription that you on Rhapsody.
Reformat how? I think I have tried that but maybe not. I’ve tried so many random things but mostly through Rhapsody.
Well, I didn’t get a chance to do this b/c I was trying to play rhapsody and it wouldn’t let me log on so I called them to fix it and just asked them for help with my clip as a side note and what do you know it (at least one of my clips) seems to be working (transferring my playlists). Not sure what we did but I did check my version of Windows media player (I have vista btw), checked my version of rhapsody then while on Rhapsody I held down ctrl+shift and clicked on tools and selected backup and reset data application directory, I got knocked off rhapsody, relogged on and did it again for fun (I was confused) and low and behold one player works. I will finish loading my playlists then try the other clip and see what happens. I am not sure what I did or why I did this or what any of it means.
