I have had my clip + for about a 4 months now and it is now totally dead (Yes I tried the reset method to no help) I plugged it into my notebook computer and it was syncing songs and it just froze (The Clip device not the computer) the computer said found new hardware and the drivers were installed so I unplugged the clip and now it will not turn on or do anything at all
Is there a way to revive this player or should I request an RMA?
I have had a Sansa Clip+ 4GB for about 5 months.Ā I was listening to it earlier tonight and it stopped playing.Ā Iād had it plugged in all day so I knew the battery was practically fully charged. A look at the display showed it as in āRefreshing Your Mediaā mode, then it switched off.Ā Removing the MicroSD card and trying the swPower button failed, as did connecting it to the computer when I got home.
However, after reading a post in a FUZE forum I tried this method and it worked:Ā I held down the HOME button and the Power button simultaneously for about 5 seconds or so.Ā When I did it I hit the Home button a split second before also holding down Power (not that that necessarily mattered).Ā After a few seconds it showed the Sansa flower, and connecting it to the computer it began to charge as normal.
I tried. and a removable disk sign showed up in the PC. but it says the disk needs to be formated.
my problem is :i saved several mp3 songs from PC to the clipās āinternal memoryā folder.
when i tried to listen to the songs, the screen says not enough space for music DB. please free 90mb. and it just has no response.
and after several times of reset, it is totally dead now.
I m also facing the same problemā¦I tries the proposed solution but its not wrkingā¦plz suggest me⦠whn i connect my device to my notebook sansa clip is not respondingā¦plz suggest meā¦
Try a desktop computer (back ports preferred). Laptops or notebooks do not put out enough power to the USB ports a lot of the time. Their goal is to āconserveā power, not āspendā it.
I know they are only $50 but my temp job just ended and I really thought the thing was dead.
I googled and this was the first page I came to and your press and hold home first⦠etc got me a Ā nice flower and ārefreshing mediaāĀ
(i get a lot of ārefreshing media.ā must remove 4GB memory chip and put in safe place)
previously, I have killed two Creative Zen Micros (which were easier to make playlists on)
now to fix the legs on my Ā 1993 Laser keyboard⦠(years ago the ex slammed his fist down on it and broke a leg. found a matching keyboard at a yard sale. had a broken leg tooā¦) Hopefully my 2003 cell phone will hold up⦠the Ā buttons are Ā getting iffy and iāve Ā killed two chargers.
anyway, hope you wander thru here from time to time so you can know your advice is still helping people. I signed up just to say thanks.
Clip+ 4GBĀ - Was freezing up onĀ a regular ly.Ā Lately on a daily basis. Yesterday it went dead and will not come back. Tried all suggestions.Ā Power button for 15 seconds. NothingĀ Then 60 seconds. Nothing. Tried Home / Power for 15 / 30 / 60 seconds. Plug in to Computer. Pluged into wall charger. Nothing Nothing Nothing!Ā Only 5 months old.Ā Now what?
Miikerman, thank you so much for responding, but Iāve been researching this all morning and Iāve pushed every combination of buttons.Ā Only thing left isto let it sit and hopefully drain the battery.Ā
I suppose the warranty would work if only I could find that darn receipt.Ā
Butā¦
WOW page after page on a dozen of different sites filed with Clip users having the same freeze up problem and the final solution seems to be letting it sit for days on end for the battery to die and then maybe have it reset itself. What for? Only to have it freeze up again. Now that seems like a great solution, Sandisk. Maybe its SanDiskās plan to forced me to buy a couple more of these dogs. So when one is sitting around frozen up draining the battery Iāll have another one to use. Seems Sandisk canāt get its act together to fix this problem. This MP3 isnāt that great that we should have to put up with this poor design and quality control. Maybe itās time to look at the Apple Products.
I love my clip+ to bits, but Iāve only had her six months and she freezes up at least once a day.Ā
It stalled on ārefreshing mediaā for an entire bus ride to work and then a whole seven hour shift in my pocket (yes really), I reset her before I got on the bus home and she wouldnāt turn back on.
Wonāt respond to any computers, Iāve used all the ports and three different cables so I know itās not that.
Right now sheās on day 2 of being plugged into the wall but sheās frozen on that **bleep** sansa flower screen. Sheāll flash that, and then turn off. Nothing more.Ā
Trying all the button combos I can think of but Iām losing hope.
My manual and such were in the old house, wah! Really canāt afford another, feeling kinda heartbroken.
