Sandisk Ultra problems.
Hallo, I’m having problems with my Sandisk Ultra card, I can’t repair it, I can’t format it, It tells me it is Write Protected even though it shouldn’t be and the files inside reapear when i delete them, I’ve tried several methods and none have worked.
Please help.
Have you tried contacting SanDisk Customer Service/Tech Support? Sounds like your card may be defective, in which case they can replace it for you under warranty.
