I have the same issue with my Sandisk Cruzer. On my pc/netbook with windows 7 64-bit SP1 ive got command :Please run SanDisk Secure Access from a SanDisk external device"<font color="#000000"> On pc with windows XP i dont have this error. This error command i have since last update of Secure Access. Can you fix it ASAP? I try with fresh downloaded version of secure access, chkdsk, other USB (2.0 and 3.0) and still doesn`t work.
3 or 4 weeks ago i run my secure acces from USB drive. After start the program showed a message that the new version is available and start download to my USB drive. When update finished the download and installation I tried to run Secure Access but unfortunately since then the program returns an error which I wrote about above.
Yesterday I tried to run the program in compatibility mode with previous versions of windows; still program returns an error.
Fresh version of secure access was extracted to the USB drive.
You are not the only one facing this problem. Even i m dacing this. First I got “Run SecureAccess from an esternal source” and now i am getting “SecureAccess is already open click on the window to display current session” even though it isn’t open. Please help.
If you’re running Windows check the icons in the Taskbar near the clock. Do you see a SecureAccess icon there? If not do you see an arrow to expand the bar? If so click on the arrow and a small window will open showing icons that are hidden. Do you see SecureAccess there?
If the above fail, click Ctrl+Alt+Del and when the Windows 7 selection windows opens click on Start Task Manager. In the Windows Task Management windows click on the Applications tab. Do you see SecureAccess running there?
Shortcut virus attack on my drive. i have official data in Secure Vault . All file shows shortcut. & main drive show hidden.If i click on login it says - Failure reading the filesystems file. i can’t open my secure vault . Please suggest any solution.
Get all the information of windows shortcut keys here on this website. computer shortcut keys This website provides all the information of windows shortcut keys. So visit here and know all the information of windows shortcut keys.
