SanDisk card won’t format
Card will not format
There can be many reasons for your SD card not formatting errors. The memory card might be corrupted. Its file system may have turned raw, or your computer doesn’t recognize the SD card. Check out this article to fix the Sandisk card won’t format issue.
Its’ possible your SD card is not properly inserted or is physically damaged. But when SD card won’t format on Camera or in Windows File Explorer, try formatting it using Windows Disk Management. This article may help.
I put a lower capacity card in and that resolved the problem Thank you
My SD card is not working
Have you tried these solutions provided in the above comments?
Hey, hawley. Could you please provide more details about the issue you’re encountering? There could be several reasons why your SD card won’t format, such as write protection or hardware failure. Understanding the cause will help identify the right fix. This blog outlines some very basic solutions, hoping they can help you.
