Just noticed that I placed it in the wrong directory, can somebody please move it for me?
I recently bought a SanDisk 16GB MicroSDHC for use with my MP4 and when I came home I put it in my computer. At first the computer didn’t even see the card but after a few tries the computer did and asked me to format it. I click OK and then on Start, after a second or two a message pops up saying that the formatting could not be completed. When I then go to the My Computer screen the card is no longer seen, unless I pull it out and put it back in.
These are the standard options for the formatting, I have no clue on what to pick and its translated from Dutch:
Capacity: 30,6MB (no other option).
System: FAT (other options are NTFS and exFAT)
Clustersize: 512 bytes (other options are Standard, 1024 bytes, 2048 bytes and 4096 bytes)
The computer is very new, so I’m quite sure the problem does not lie there.
Help is appreciated, thanks in advance.
