I’m considering buying a Fuze but will only do it if Rhapsody files work on the SD card (which they didn’t in the earlier Sansa e280 model). I’ve read various things in this forum with some saying they work and others saying they don’t. Can someone confirm that I can put Rhapsody subscription tracks on the SD card? Also can you confirm that I can go up to 16GB on the SD card with the Fuze? Thanks!
yes rhapsody works with your sd card and the player can go up to 16gb and 32 in the future
