Since ReadyCache is at End Of Life can anyone recommend another SSD cache drive alternative?
Great so mine finally works and its no more updates? Are you serious:(
SanDisk has not EOL’d ReadyCache. It is still available for sale and it is supported.
gls wrote:
“SanDisk has not EOL’d ReadyCache. It is still available for sale and it is supported.”
That is a blatant lie. It is not supported. Look at the posts! ![]()
I have already contacted the Department of Consumer Affirs involved in my State in the USA.
Again, please don’t buy this product - you will be stuck with it and it’s multiple problems.
You can’t even use the whole cache without continually flushing it or having a reset.
Nobody from SanDisk even cares… What a ripoff.
Flavio ![]()
They should at least give us info about new updates.
Will there be an application update?
When will it release?
What’ re they try to fix?
What will be the new release notes?
