First message after reading the forum forever. Thanks to the developers for continuing to work and support the product. Thanks to the constructive users for offering feedback. I haven’t seen this question so far so thought I would ask.
I recently upgraded to a 16 GB fuze+.
I have a 8GB fuze v2 with 16GB micro sdcard and a 8GB fuze v2 with 32GB micro sdcard. For fuze v2, I put playlists directly on the micro sdcard using the convoluted prescribed way (MSC mode, then MTP, then…whatever…I did it…it worked).
My goal was to take the cards out of the v2 and into the fuze+ and not have to worry about recreating the playlists that are on the card. However, I quickly noticed that the playlists on the card do not appear when inserted into the fuze+ (regardless if I am in the integrated music list or the sd card section).
Before I complain, I need to say that I understand the product is evolving and I don’t mind working through the change. The “gapless” playback is a delight (most of my music is continuous house music…it is great to not have to skip a beat between tracks). The fact that the player supports some of the “newer” file formats is also the primary reason why I finally upgraded. I have learned how to manipulate the touchscreen so that I can work with it (I tap the cross more than “scroll” it…tapping is more intuitive with the dots at the bottom of the screen).
I won’t complain about the UI sluggishness (yes, I have a full library on both internal and external card - I like all of my stuff on one device). I know the developers are working on it. I’m not a huge fan of the SD Card menu, but if it is there…whatever.
However, 2 questions:
First question is about the playlists from legacy fuze v2 on micro sd cards. Do I have to recreate them? (i would prefer to have the flexibility of interchanging the cards between devices).
Second question - when watching videos in fuze v2, tap right once would advance 30 seconds while hold right once would advance by 1 second until released. However with fuze+, it doesn’t seem to work that way.
I know that this was a long post, but wanted to make sure I was clear with my questions.
Again, I would like to continue to support this product. Any help you give will be appreciated.
