I’ve discovered that the Clip balks at certain characters in some ID3 tags, and this results in the lockup issue many users are experiencing. This is NOT a “number of files” issue as suspected by some…
The easiest way to work around this (until Sansa fixes the firmware), is to change all your music files to use Unicode (UTF-16) for the ID3 V2.3 tags. If you are using the (excellent) MP3Tag utility, this is one of the Option settings.
You can simply select all your MP3s in the utility (you can even do this without deleting them from the Clip, if you do the power reset, have firmware V x.18, and are in MSC mode) and then just hit Save; any files in the “bad” tag format will be converted / corrected to the “good” Unicode format - and the Clip will then be happy with them ALL when loaded with them or disconnected.
Ahhhmmm, “PROVEN” means “it works”. So let’s find out why it didn’t work for you:
Did you read my post thoroughly, maybe also check out the Mp3tag HELP menu, and set the required options?
You must go into the Mp3tag Options / MPEG menu and make sure BOTH id3 version “read” checkboxes are checked, both id3 version “write” check boxes are checked, both id3 “remove” checkboxes are checked - and MOST IMPORTANTLY - that the write option for Unicode tag text formatting (the center radio button, the one that says “ID3 v2.3 UTF-16”) is selected.
Now, when you drop a folder of MP3 files into Mp3tag, go to the Edit menu, click Select All. Then just click the Save icon, and Mp3tag will change any files that have the “bad” id3v3.2 ISO text encoding, over to UTF-16 (Unicode) and the Clip will NOT stall on the database refresh.
As a side benefit, any MP3s that do not have ANY id3 v2.3 tags will get them, using the v1.x data.
BTW, using consistent tagging will also minimize or eliminate the multiple database entries for genres/artists, so I recommend retagging all your MP3s by this procedure, if you are having that problem…
Dear guru. I am trying to solve a different problem with the same tool. I have some mp3 files with Russian ID3 tags. I used the same tool and made sure that they are converted to V2.3 ID3 tag Unicode. However, my Sansa m200 does not show Russian font correctly. However, file name in Russian shown fine. Any ideas, please?
I’ll have to give this a whirl if this happens again. Although I don’t think my refresh database problem could be deduced to this as the same files that were freezing my clip before, work fine now, and the tags are the same.
when your player got locked up in refresh DB…slide up the power button and hold there for 15 seconds to reset…after the reset, DO NOT turn your player on, but put it in LOCK mode by sliding the button back…then press and hold the center button while plugging it in your PC so the player will connect in MSC mode…then back up your data in there…do a format & upgrade firmware and reload your contents to see if this will solve your problem.
