I was listening to my sansa clip+ and it just turned off in the middle of a song. I haven’t had any problems with it before and I’ve only had it 2 or 3 months. I tried turning it on and plugging it in and charging it, but neither will work.
Any ideas?
Thanks.
it may be frozen. try holding the power button for about 20 seconds. if it is frozen this should reset it. then try turning it on.
Reset it, Les.
Mine just did that. I tried that and now it’s back up and running again (fingers crossed). Thanks for the info.
