Player connects to computer but will not charge
To Tallnproud:
May I ask what computer you are using to connect to the Clip?
I have burned through 3 of the lil’ buddies since my first purchase of a Clip in Oct/Nov.  I have the same story - works great, love it, then one day, it just stops working, boom!  Since it seems that many people don’t have these problems, I’m wondering about the computer itself - some bug or electrical (of sorts) problem.
Mine was doing this also, straight out of the box today. Once I downloaded the upgraded firmware adn used it------no problem. So far…?
I have noticed that after upgrading with the firmware that using my old Motorola phone jack the clip will not recharge the battery.
I have noticed that with the white connection cable that was included in my purchase that the clip will charge when pluged in.
The only difference I have actually observed is the small round plastic coated “bump” on the factory charging usb cord. Maybe there is a resistor, or …inside of it that is causing it to cause the different behavoir. If anybody has an old factory usb chord htey are willing to dismantle we can find out.
Message Edited by Cacher on 08-10-2008 12:08 AM
Thank you so much…i was having the exact same problem…you helped me and now i have my musakkk once again…you saved my life literally…thank you so much…
Thank you miracle worker,
eccentricpolly
