I just purchased a SanDisk Connect Wireless Stick. I copied all of my songs from my phone and iTunes to the stick. I now want to play them on my iPhone. They won’t play directly from San Disk Connect. How can I play them without first copying to the iPhone? I bought this because my iPhone is maxed out on memory.
m4p are DRM protected files. you will need to remove the DRM protection from the file or convert the file to a compatible format in order for the connect drive app to play it.
