A fresh out-the-box WD My Passport Ultra is not working on my Dell Laptop running XP. The laptop uses hard drives of various types without any problem. When this new one was connected the software run successfully but when I go to the file manager the drive cannot be seen. Any thoughts? Thanks for your time
TimB
Cape Town
Pretty sure all the My Passport Ultras leaving the factory are formatted GPT Partition Style … which is not compatible with Windows XP 32-Bit (which only supports MBR)
(GPT is supported on WinXP 64-Bit, Win 7,8,10)
Guess you’ll have to use WD Quick Formatter (and choose XP Compatible mode) and backup any supplied software before you wipe the drive.
More Info Here …
http://support.wdc.com/KnowledgeBase/answer.aspx?ID=1695
Thank you for that suggestion. It worked.
Best
TimB
good to hear
please tag it as “Solved” … thanks
I am struggling to find the Solved tag…I looked in the ellipsis with no success…any tips?
