For some reason when I plug in the charger my Sansa Fuze will not charge. I now have a yellow lightning bolt showing up when I plug the charger in, which is located next to the green bar that shows how fully charged the player is. The charging indicator is continuously blinking green to white back and forth from right to left.
Does any one know if this is due to a problem with the charger, or the unit itself and what I need to do next steps to get this problem resolved and get my much beloved Sansa up and running again.
Thanks–Randy
Thanks–Randy
What you’re describing means that it is charging.
