Bought so i can transfer files between a Windows 7 64bit and a wiondows XP 32bit. Even thought my MyPassport elite works on either one, the 750gb will not showup on the xp machine( formatted the 750GB on the Win 7 ). I get the hardware found and installed plus the ding but it is not in My computer or the disk management. Help please
LarryR
I’m willing to bet that the passport is not getting enough energy from the XP computer, avoid using USB hubs or USB extension cables and connect the passport directly to the computer.
You were right. But i took it back anyway , and got the Mypassort essential. Worked right off . Not sure about plugging into hubs always heard not to unless its about none powerd ones.
Thanks for the help
LarryR
