My "MyPassport" not recognizedThanks in advance for support
Having a portable external My Passport drive for some years but not used. Fixing the cable in usb-port in the pc browser is only to be seen under “C” F: WD Unlocker.
Request: may I reformat the drive My Passport and installing new software? All data is old so of no importance. And which software? Where to be found?
Search on WD but only than I found WD My Cloud software which we use also.  But this drive is an extra drive. I am using Windows 7 on this laptop.
Thanks in advance for reply.
Hi there and welcome to the WD community.
I believe if you try to put the password incorrect 5 times you will get a prompt to erase the drive since it is the way that you will be able to use the drive after its locked.
Here is a link that might help you with the software which is WD security:
http://wdc.custhelp.com/app/answers/detail/a_id/10408/
