fuya
1
I have a book duo that I bought 2 years ago. I use the 2 hard drives as a mirror.
They are full now and I want to buy new hard drives that fit in the Book Duo. I can’t find exactly the same model WD60EFRX
What drives should I buy that fit in the Book duo WDBLWED?
john15
2
Hi fuya,
You should contact WD Support for such an issue. To contact WD support, you can refer to the links mentioned below.
Phone:
https://support.wdc.com/contact_phone.aspx?h=4
Email:
https://westerndigital.secure.force.com/ind/?lang=en
