Hello.İ bought a 32gb microsd card from sandisk. But i cannot use it beacuse it akways deletes anything i put in it. Therefore i lost some of my important documents. Could someone help me to solve my problem.
Hey Catcircuit, Try to download the demo version of stellar phoenix photo recovery software for view your deleted lost files after seeing the preview you can purchase and save the lost data from your SD card. more detail: https://www.stellarinfo.com/digital-media-recovery.php
In this stuation ,i think you may need a third-party software and you shouldn’t use your microsd card, because new data will overwrite your previous deleted data. keep in mind.Search Doctor for Android in Google,you could find solution.
Do you find it?Here you go:MobiKin Doctor for Android
I think this is a problem.Do you means the data is disappear automatically instead of somebody deleted them.
In that way,please stop use it to avoid overwritten.You could find some recovery tool which support SD card,scan your card first.
If it could scanned the data that you missed,then it could recovery them successfully.
Hope it useful,thank you.
HI there are 5 ways you can solve this problems i hope this will be helpfull for you!![]()
solution 1: restore Corrupted MicroSD Card
If the documents which you transfer to SD card keeps getting deleted or corrupted, it can be a sign indicating that your SD card is corrupted after lengthy-term use or negative first-class. So the first element you need to strive is to restore the corrupted reminiscence card with the aid of undertaking chkdsk command or formatting your SD card with a computer.
test out the stairs to repair corrupted SD Card on Android smartphone.
If the SD card is can not be repaired, maybe it’s time to get a new SD card.
solution 2: Unmount and Re-insert SD Card
If the pics, track, or documents do not show up inside the Gallery or play-lists however you can nonetheless discover them within the folder of your report supervisor, you ought to try to re-insert the SD card to solve the hassle.
go to Settings > storage.
under your SD card, choose “Unmount the SD card”.
Then electricity off your Android smartphone. Take your SD card out of the cellphone.
After some time, re-insert the cardboard and strength on the telephone.
Now test if the deleted or corrupted photographs, songs or documents arise.
solution 3: Delete the Nomedia file
A Nomedia report is a files saved on an Android telephone or on an SD card connected to an Android tool. It tells the multimedia gamers that there are not any multimedia data in its folders so the players won’t scan the cardboard. If there’s a Nomedia report for your phone, your files on SD card are hidden, no longer deleted or corrupted. seeing that Nomedia file is hidden and invisible to most construct-in file explorers, you need 1/3-party file explorer which include ES document Explorer to get admission to and delete the report:
Open ES file Explorer and tap the blue icon in left top corner.
faucet tools and toggle on “display hidden files”.
The Nomedia report will seen.
Delete the file.
Delete Nomedia documents on Android
solution four: keep away from transfer Many files At One Time
some users located that the files moved to SD card got corrupted simplest whilst they’re transferred to SD card in large bulk. in order that they tried to lessen the paintings load by means of shifting like SD transfer 5 pics at a time. And a few users have been satisfied to locate that they by no means get the corruption blunders once more. but this trick does not paintings for absolutely everyone.
solution 5: Uninstall difficult programs
a few people found that their SD card files failed to get corrupted until they had a certain app installed on their phones. if so, it’s far the tough app that reasons software conflict. So attempt to bear in mind if you have lately install a brand new app, specially out of doors of Google Play store. in case you did, uninstall the app and clean all its statistics to look if your SD card works first-class after the uninstallation.
answer 6: repair factory Settings
If none of the answers are helpful, your Android cellphone could be the problem. try to perform a factory reset to provide your phone a clean new begin. however this can erase all information and settings for your Android cellphone. therefore you have to use the manufacturing unit reset as the remaining resort and continually backup your information earlier than resetting.
SD card is a first-rate garage alternative, however it isn’t secure sufficient, particularly you have buy a microSD card with limited price range. therefore, when you have a few truly essential statistics, it is higher to choose a more secure garage alternatives:
Backup the documents on pc. FonePaw Android statistics recovery can help you switch pix, motion pictures, tune, contacts, messages, WhatsApp messages selectively from Android phone to laptop/Mac.
upload the documents to cloud garage, consisting of Dropbox, Google drive. but there may be just confined garage if you don’t purchase greater storage.
fix statistics restoration on Android and SD Card
when the documents is deleted or corrupted, there are some methods to get better them returned but a number of them are complex so if you generally tend to do report restoration by way of yourself, test below:
recover deleted or corrupted files on Android cellphone & memory card: For each Android smartphone and the SD card in it, FonePaw Android statistics healing will examine them and help you restore the lost documents however it could take a longer time.
recover deleted or corrupted documents on SD card simplest: FonePaw statistics healing allows you to scan the facts on SD card with connecting the cardboard reader to computer. This approach does not root your tool because it might not do some thing with gadgets.
there are 6 answer to solve problem regarding sd card
answer 1: repair Corrupted MicroSD Card
If the documents which you transfer to SD card continues getting deleted or corrupted, it could be a sign indicating that your SD card is corrupted after long-time period use or bad satisfactory. So the first element you need to attempt is to repair the corrupted memory card via engaging in chkdsk command or formatting your SD card with a computer.
test out the steps to restore corrupted SD Card on Android phone.
If the SD card is can not be repaired, perhaps it’s time to get a brand new SD card.
answer 2: Unmount and Re-insert SD Card
If the pictures, music, or documents don’t show up within the Gallery or play-lists however you may nonetheless discover them in the folder of your document supervisor, you have to try to re-insert the SD card to remedy the hassle.
go to Settings > garage.
under your SD card, pick “Unmount the SD card”.
Then electricity off your Android cellphone. Take your SD card out of the smartphone.
After a while, re-insert the cardboard and power at the smartphone.
Now check if the deleted or corrupted images, songs or documents come up.
answer three: Delete the Nomedia file
A Nomedia record is a files stored on an Android cellphone or on an SD card related to an Android device. It tells the multimedia gamers that there are not any multimedia records in its folders so the players may not scan the cardboard. If there is a Nomedia record to your cellphone, your documents on SD card are hidden, not deleted or corrupted. in view that Nomedia record is hidden and invisible to maximum construct-in record explorers, you want 1/3-celebration report explorer which includes ES file Explorer to get right of entry to and delete the report:
Open ES report Explorer and tap the blue icon in left higher nook.
faucet tools and toggle on “display hidden documents”.
The Nomedia report will visible.
Delete the document.
Delete Nomedia files on Android
solution 4: keep away from switch Many documents At One Time
some customers found that the files moved to SD card got corrupted best whilst they may be transferred to SD card in large bulk. so they attempted to lessen the work load by means of shifting like SD transfer 5 photos at a time. And a few users were happy to discover that they by no means get the corruption errors again. however this trick doesn’t work for anyone.
answer 5: Uninstall difficult packages
a few humans found that their SD card files didn’t get corrupted until they had a positive app hooked up on their telephones. if so, it is the troublesome app that causes software war. So try to bear in mind when you have lately installation a new app, particularly out of doors of Google Play store. in case you did, uninstall the app and clear all its facts to peer if your SD card works high-quality after the uninstallation.
answer 6: restore manufacturing facility Settings
If not one of the solutions are helpful, your Android smartphone can be the hassle. try and perform a manufacturing facility reset to present your phone a sparkling new begin. however this could erase all information and settings on your Android cellphone. therefore you need to use the factory reset because the closing resort and always backup your facts earlier than resetting.
SD card is a outstanding storage option, however it isn’t safe sufficient, mainly you’ve got purchase a microSD card with restricted price range. consequently, if you have some virtually vital information, it’s miles better to select a safer garage options:
Backup the documents on computer. FonePaw Android records restoration allow you to transfer pics, films, track, contacts, messages, WhatsApp messages selectively from Android cellphone to pc/Mac.
upload the files to cloud storage, which include Dropbox, Google force. however there is simply constrained garage if you do not purchase greater storage.
restore data healing on Android and SD Card
when the files is deleted or corrupted, there are a few approaches to get better them returned but some of them are complex so in case you tend to do report recovery through yourself, check beneath:
get better deleted or corrupted documents on Android phone & memory card: For each Android smartphone and the SD card in it, FonePaw Android information recuperation will examine them and assist you restore the misplaced documents but it is able to take a longer time.
recover deleted or corrupted files on SD card handiest: FonePaw facts restoration lets in you to scan the statistics on SD card with connecting the cardboard reader to pc. This technique doesn’t root your tool because it won’t do something with devices.
recover from SD Card handiest
regards - harish warma
This doesn’t happen with an original card, is it genuine? If yes, chances are that your card is corrupted. As far as your files are concerned, I would recommend you to use a good recovery tool like Stellar Photo Recovery and try to get your data back.
Hope it helps!
This is solely required for migration to MoEngage Platform. We need your help to tell the SDK whether the user is a new user for on your app or an existing user who has updated to the latest version. How To Turn Off Find My iPhone Without Password
If the user was already using your application and has just updated to a new version which has MoEngage SDK it is an updated call the below API
Coolmuster Android SD Card Recovery, which aims to help restore deleted files on Android SD card under various circumstances, such as getting phone infected by viruses, formatting the SD card or making improper operations, and so on. With it, your lost files on the SD card can be scanned and displayed on the menu with details. Then you can freely view and recover deleted photos, videos, music and documents as needed. By the way, you are able to regain all lost files in a batch.
The microSD card’s file system may be corrupted, which can prevent it from properly storing files. You could try formatting the card (preferably with a tool like SD Formatter) to see if that resolves the issue. On the other hand, some counterfeit or defective microSD cards appear to store files but actually have much less storage than advertised.
Since you’ve lost important documents, I recommend trying free data recovery software to see if you can recover your files before attempting to fix or replace the card.
