Issues on Vista with Sansa Clip 4gb player
I recently picked up a Sansa 4gb Clip player from a local Best Buy.  Seemed like a great idea at the time, has turned into a giant headache thus far.  I am using Vista Service pack 1 32-bit.  I’ve read just about every thread/forum pertaining to issues on this player.  I’ve switched modes on the player, grabbed the mtp fix for mplayer.  I currently have media player 11.  I’ve done everything thinkable.  I don’t have an XP system to test this on, I read that you can firmware update it on an XP system to get this to work on vista.  Any ways to work around this,  I’ve contacted Sansa with my issue.  Anyone find any means to fix this problem that excluded whats already mentioned out there?
What exactly is the problem? You listed a ton of fixes, but you didnt mention the problem.
I’m sorry.  Vista can’t locate correct drivers for the device.
AHH HAA. Ok What USB mode are you in? The drivers are not spesific to the fuze. Have you tried a flash drive? It may be such a thing as Vista is having trouble with its USB support, Make sure you have all the upgrades, I know I installed 4 more this morning.
Flipped between MSC and MTO yesterday, same issue today.  Neither work.  Vista see’s my other usb devices, and even my flash drive fine.
The issue is Vista or Windows specific.  I was in the lab today on a linux based system, and it saw the portable mp3 player alright.
Its Vista. But not all Vista. Make sure your USB Drivers are up to date, and tht vista is up to date.
That I know of my vista usb drivers are up to date as is my O/S
Did you try updating to the latest firmware for your device? Its at the top of the Clip Forum.
Yes, I managed to get on an XP system in the lab.  Updated firmware, no change.
I’m apparently the 2% of people that has issues with it on vista.
