Is there a way to charge on usb & listen to it? I bought it to mount on my motorcycle, haven’t opened it yet (Christmas present), was thinking battery life didn’t matter because I have a usb charger on the bike I can leave it plugged in. If not, is there any way to charge & play at the same time? May have to return it…Thanks
I use mine at work and use an AC USB charger to power the unit. Your bike USB charger should work fine.
However if you plug the unit into a computer you CANNOT listen to music/the radio etc.
Plug half-way the usb cable and you are good to go
There are two sets of pins in the cable. One is for charging, one is for data. The charging ones are a little longer. Hence the suggestion to plug it in partway.
But I suspect your USB charger doesn’t have data pins at all, so you should be fine.
