I purchased an ixpandable 64gb flash drive for my IPAD, but can’t get it set up. Do I need to install some software on my IPAD?
THANKS FOR ANY HELP,
BOB HANBURY, MELROSE,MA
Hard to say Bob.
as far as i can understand you own the ixpand drive and want to know if you need to install the ixpand sync in order to use it with your ipad.
i would like to inform you that you need the app in order to use the ixpand with the ipad because without it you cannot access it normally.
I don’t know what the name of the app is; and where I where I would get it.
Thank you for your help,
Robogon
Go to the App Store on your iPad and search for SanDisk iExpand.
Thank you. I went to Apple Store site, but all they offered me was an apple version of the flash drive, not the app I need.
Thread continues here:
http://forums.sandisk.com/t5/SanDisk-iXpand/Re-Ipad-4-and-iexpandable-64gb-flash-drive/td-p/338589
Not the “Apple” store, but the “App” Store. You access it from your iPhone or iPad. There is only one; it’s called SanDisk iExpand Sync.
You did buy the SanDisk iExpand flash drive, didn’t you?
Edit: I am going to suggest to the Mod that this thread be moved to the more appropriate SanDisk iExpand board.
All i get for clicking the link is “Invalid Parameters.”
I just downloaded and installed the SanDisk iXpand Sync on my iPad and all I get is a “Firmware Update In Progress” with a never ending series of dots rotating.
